J
Just replaced the clutch slave cylinder on my 97 155 2.0 16v and wondered if I correctly bleeded the system. Is a bleeding kit necessary? I just pumped the pedal a few times with the bleeder open until fluid came out. The clutch seems to be working ok but am afraid that I might have trapped air in the system.
Thanks.
If it's working okay then that should have done the trick. Normally you use a bleed kit or one of those rubber tubes with what looks like a nail stuck in end so that when you release the pedal, air doesn't get drawn back in.
Ralf S.
Sounds like it is ok as it's working. The clutch pedal should become a little lighter near the bottom if its all ok. Hopefully the pedal feels the same as it did before you had trouble.
J
Thanks for the reply lads.
The pedal feels a bit different. Though, it could just be my paranoia. I might invest in a bleeding kit and rebleed the system (one day).
W
I've just done this job and the pedal doesn't feel right, it has a bit of stiffness about halfway down. Works ok apart from this but I plan to bleed it agian just to be sure.
wrinx
C
I did it without a bleed kit and spent the next 10 minutes wiping the fluid off the car. :rolleyes: It dont half come out fast, I had a jet a good foot high.
J
Happened to me too - the jet hit the bottom of the bonnet and splattered everywhere!
W
Bit of pipe over the bleed nipple...into a jam jar :D
wrinx
