1 - 20 of 29 Posts
How effing cruddy are Bosch mafs for the V6?:mad:
Previous owner fitted one less than 12 months ago and its gone already, L|ess than 5k miles done.
Sudden glitch for a good second, while tonking it at 5k rpm, idels very rough, hesitancy on pick up and Alfa diag confirms not working.
The pieburg maf in my Seat has been good for 5 years and 40k miles.
Aaargh
Hunting down cheapest TS CF2 to swop sensor. Any bargains known about?
sure it was a bosch sensor?
0
^^What He said - not heard about a genuine one going so soon
What is Alfadiag telling you?
I'm a little puzzled. Why do you want a TS CF2 MAF if it's a V6 MAF giving trouble? :confused:
:confused:
Awe naw not that old red kipper again;):D:cheese:
Or did you leave the 166 lounge too fast :cheese:Mitch.:lol:
Pomeo
Must have done mate, missed this one!
There is a thread on here at the moment where someone has bought a vauxhall MAF for £58 took the sensor out of the housing and just replaced the sensor as it's the same part number as the sensor part on the V6 alfa .
I'd put the link on here but I'm using tapatalk on the iPhone and there's no link on it.
Mitch - the sensor inside the TS maf is identical part and in fact identical to that fitted to Vauxhaul 1.7 diesels - the difference is the tube diameter, which affects the airflow over the sensor. Basically Bosch and parts companies shaft you for having a V6
Will get back with Alfadiag code/description. I've removed maf, cleaned it with electrical contact cleaner thoroughly, cleaned all contacts and put dieletric grease on.
Fault code returns seconds after clearing it.
:cool:
So are all TS sensors the same? The CF1 TS MAFs are really expensive, even compared to a CF2 TS MAF. It would be a right result to find out the sensors are identical.
Sadly, they're not.
Edit:
Bosch 0280217111 is for CF1 212€
ALFA ROMEO
GTV Coupé (916)
2.0 T.S. 16V 110kW 04.95 > 09.00 AR 16201 CF2 [916] 04.95-03.98
Spider
2.0 T.S. 16V 110kW 04.95 > 09.00 AR 16201/32301 [916] 04.95-03.98
145
1.6i.e. 16V T.S. 88kW 11.96 > 02.99 AR 67601 [930G97]
1.7i.e. 16V 96kW 04.94 > 11.96 AR 33401 [930]
1.8i.e. 16V T.S. 103kW 11.96 > 04.98 AR 67106 [930G97]
1.8i.e. 16V T.S. 103kW 05.98 > 02.99 AR 32201 [930G97]
2.0i.e. 16V T.S. 110kW 11.96 > 04.98 AR 67204 [930G97]
2.0i.e. 16V T.S. 110kW 05.98 > 02.99 AR 32301 Step A [930G97]
146
1.7i.e. 16V 96kW 12.94 > 11.96 AR 33401 [930]
2.0 ti 16V T.S. 110kW 10.95 > 04.98 AR 32301 Step A [930G97]
2.0 ti 16V T.S. 110kW 10.95 > 04.98 AR 67204 [930G97]
2.0i.e. 16V T.S. 110kW 05.98 > 12.99 AR 32301 Step A [930G97]
155
1.6i 16V T.S. 85kW 05.96 > 10.97 AR 67601 [167G96]
1.8i 16V T.S. 100kW 05.96 > 10.97 AR 67106 [167G96]
2.0i 16V T.S. 110kW 05.96 > 10.97 AR 67204 [167G96]
2.0 T.S. 16V 110kW 03.95 > 04.96 AR 67204 [167]
156
1.6 TS 16V Berlina 88kW 46.98 > 09.00 AR32102 CF2 [932] 04.98-06.98
1.6 TS 16V Berlina 88kW 10.97 > 09.00 AR67601 CF2 [932] 10.97-06.98
Bosch 0281002309 is for CF2/3 111€
ALFA ROMEO
GTV Coupé (916)
1.8 T.S. 16V 106kW 03.98 > 12.00 AR 32201 CF2 [916] 10.00-12.00
2.0 T.S. 16V 110kW 06.00 > AR 32310 CF3 [916]
Spider
1.8 T.S. 16V 106kW 03.98 > 12.00 AR 32201 [916] 10.00-12.00
2.0 T.S. 16V 110kW 09.00 > AR 32310 CF3 [916]
147
1.6 TS 16V 88kW 11.00 > AR 32104 [937]
1.6 TS 16V ECO 77kW 11.00 > AR 37203 [937]
2.0 TS 16V 110kW 11.00 > AR 32310 [937]
2.0 JTS 16V 121kW 09.02 > 937A1.000 [937]
156
1.6 TS 16V Berlina 88kW 09.00 > 12.01 AR32103 CF3 [932]
1.6 TS 16V Berlina 88kW 09.00 > 12.01 AR32104 CF3 [932]
1.6 TS 16V Sport Wagon 88kW 09.00 > 12.01 AR32104 CF3 [932]
1.6 TS 16V Berlina 88kW 01.02 > AR32104 [932MY01]
1.6 TS 16V Sport Wagon 88kW 01.02 > AR32104 [932MY01]
1.8 TS 16V Berlina 106kW 00000000 > AR32205 [932MY01]
1.8 TS 16V Sport Wagon 106kW 00000000 > AR32205 CF3 [932]
1.8 TS 16V Berlina 106kW 00000000 > AR32205 CF3 [932]
1.8 TS 16V Sport Wagon 106kW 00000000 > AR32205 [932MY01]
1.9 JTD 80kW 09.00 > 12.01 AR37101 / 937A2000 [932]
1.9 JTD 85kW 01.02 > 937A2000 [932MY01]
2.0 TS 16V Berlina 114kW 09.00 > 12.01 AR32310 CF3 [932]
2.0 TS 16V Sport Wagon 114kW 09.00 > 12.01 AR32310 CF3 [932]
2.4 JTD 100kW 09.00 > 12.01 839A6000 CF3 [932]
2.4 JTD 110kW 01.02 > 841C000 [932MY01]
166
2.0 T.S. 16V 114kW 09.00 > AR 36301 CF3 [936]
2.4 JTD 100kW 09.00 > 839A6000/841C000 [936]
Bosch 0280218019 CF2 109€
ALFA ROMEO
GTV Coupé (916)
1.8 T.S. 16V 106kW 03.98 > 12.00 AR 32201 CF2 [916] 04.99-10.00
2.0 T.S. 16V 110kW 04.95 > 09.00 AR 16201 CF2 [916] 04.99-09.00
Spider
1.8 T.S. 16V 106kW 03.98 > 12.00 AR 32201 [916] 04.99-10.00
2.0 T.S. 16V 110kW 04.95 > 09.00 AR 16201/32301 [916] 04.99-09.00
145
1.6i.e. 16V T.S. 88kW 02.99 > 12.00 AR 67601 [930MY99]
1.6i.e. 16V T.S. 88kW 02.99 > 12.00 AR 32102 [930MY99]
1.8i.e. 16V T.S. 103kW 02.99 > 12.00 AR 32201 [930MY99]
1.9 JTD 76kW 02.99 > 12.00 AR 32302 [930MY99]
1.9 JTD 76kW 05.98 > 03.99 AR 32302 [930G97]
2.0i.e. 16V T.S. 110kW 02.99 > 12.00 AR 32301 [930MY99]
146
1.8i.e. 16V T.S. 103kW 05.98 > 02.99 AR 32201 Step A [930G97]
1.9 JTD 76kW 05.98 > 12.99 AR 32302 [930G97]
2.0 ti 16V T.S. 110kW 05.98 > 02.99 AR 32301 [930MY99]
156
1.6 TS 16V Berlina 88kW 46.98 > 09.00 AR32102 CF2 [932] 06.98-09.00
1.6 TS 16V Berlina 88kW 10.97 > 09.00 AR67601 CF2 [932] 06.98-09.00
1.6 TS 16V Sport Wagon 88kW 06.00 > 09.00 AR67601 CF2 [932]
1.8 TS 16V Berlina 106kW 05.99 > 09.00 AR32201 CF2 [932]
1.8 TS 16V Sport Wagon 106kW 00000000 > AR32201 CF2 [932]
1.9 JTD 76kW 19.97 > 09.00 AR32302 CF2 [932] 05.98->
2.0 TS 16V Sport Wagon 114kW 10.97 > 09.00 AR32301 CF2 [932]
2.0 TS 16V Berlina 114kW 06.00 > 09.00 AR32301 CF2 [932]
2.4 JTD 100kW 10.97 > 09.00 AR 32501 CF2 [932]
166
2.0 T.S. 16V 114kW 10.98 > 09.00 AR 34103 CF2 [936]
2.4 JTD 100kW 02.99 > AR34202 CF2 [936]
Not sure if the prices are the same in the UK as they are here.
Yes but those Bosh numbers are for the whole MAF unit. We know that they are listed differently for all the engine types. What this is about is the actual sensor part, not the outside body. looking on the 156 thread, it has been found that the V6 sensor is actually the same as the TS sensor. My question is, are all TS sensors the same?
D
Aaargh
Just paid my local motor factors £ 70 for a cf2 bosch maf if that helps
Dav
Discussion Starter #15
Mitch, the important number is the F ----- number stamped on the sensor itself
On the CF2 Twinkie /V6 most models its F 00C 262 030
Check what your exisitng sensor has on it
Discussion Starter #16
Fitted my new maf - sensor from Astra 1.7CDI :wow: £64.00
Thats one hell of an expewnsive bit of eversoslightly wider pastic tube for V6.
Writing to Bosch to ask why they are ripping us off.
What year and model engine is your V6 as I need a new sensor for mine too.
Discussion Starter #18
Its a 1999 Think its a CF2 as its flyby wire throttle with 2 lambdas (my 166 was a flyby wire with one lambda and 1999 and used same sensor)
Just take your sensor out and check if its F 00C 2G2 030 (not 262 as I put earlier)
Ignition light gone, no hesitation, full rev range and smooth idle all back.
So will be looking at refund from somewhere as have recipt for new maf less than 12 months old from previous owner.
1 - 20 of 29 Posts
