1 - 2 of 2 Posts
2.0 ts phase 2 spider, the rear brake bleed nipples are seized in so are going to be damaged in removal, I would like to have correct stainless steel versions here for when i remove them but I am coming up with different sizes
Are they M7 x 1.0, M8 x1.25 or M10 x 1.00
I have seen all 3 sizes listed.
The existing nipple has an 11mm nut on it if that helps
Also does length matters, if so how long should they be?? (yes i know your other half says it doesn't)
Many thanks
I can’t remember the size but I got a set from Alfaworkshop. They have either the fronts or rears (sorry can’t remember which) listed on their website. The others they had but had them listed for another Alfa and I found them by searching for the part number. I’ll measure them and let you know how big they are if I can remember where I put them... sorry I haven’t really helped have I?
1 - 2 of 2 Posts
