OK, the spanner width is 11 mm. I have found 2 types of bleed nipples with 11 mm spanner width:
M10x1, 36 mm long
M10x1, 30 mm long
Which one is correct? It is a 2000 year model.
M10x1, 36 mm long
M10x1, 30 mm long
Hi, i would like to change the bleeding nipples too and the spanner width is also 11 mm.
I'm driving a Alfa GTV 1.8 TS (4001 040, 15.09.00, ZAR91600006062772 8). Did you find out how long the bleeding nipples have to be?
If you have not found it out yet, I can tell that both 30 mm and 36 mm will do the job. The 36 mm will protrude a bit futher out from the caliper, but it works all fine.
