1 - 2 of 2 Posts
2006 GT , standard Blaupunkt unit (937?), with Connect 2.
With this unit you can feed a line in or USB to play music etc., change the source to
'Changer' and it works well.
But for some reason it sometimes does not 'see' that there is a changer unit and so will not work.
Any thoughts?
You can check the connections on the unit but the factory units are pretty buggy at the best of times and they tend to die badly as they get older.
My 2001 147 for example sometimes switches [by itself] to CD changer despite the car not having one at all. The amp is also failing rather hopelessly on my unit too.
Best thing to do, turn the unit off and then on again a few seconds later and it should be 'normal' again?
1 - 2 of 2 Posts
