Hi All,
Has anyone ever considered using a biodiesel blend to increase lubrication and burn quality on these engines? Having looked at a few scientific studies it is often found that there is a huge increase in lubricity of the fuel when mixing 2-4% Biodiesel with regular diesel.
Note first in class on this scientific independent study
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
and this one as well
http://biodiesel.org/docs/ffs-performace_usage/lubricity-benefits.pdf?sfvrsn=4
I am considering a 2-3% blend with regular diesel to help reduce fuel pump and injector wear. The only negative is when running strong mixes on a car with a DPF you can get the oil diluted by the biodiesel but I can't imagine that being a huge issue at a 2-3% blend! Only around 25%+
What do you think?
What do you think?
