A bit of a tabloid title, but in the absence of a proper 'project' thread I thought I might as well share a couple of pictures of the lovely rust I've found so far in my 156 GTA SW.
Luckily it's all just surface rust and a good clean with a wire brush or scurfing with a grinder got off the worst, though I needed to chip away some of the larger crusts with a small chisel.
It could have been a lot worse (e.g. if it was a late 90s merc!) but I'm glad I did this job now and not 5 years down the line, when the strut top and subframe mount rot could have become terminal.
At the risk of teaching granny to suck eggs, next time you have to change that annoying upper arm, make sure you give the surrounding components a good going over with a wire brush and a good coat of hammerite or something similar. Otherwise you could be looking at something a whole lot worse a few years down the line...
