Any recommendations on keeping them nice and shiny yellow? Read many harrowing stories of aggressive wheel/brake cleaners taking the shine off.
I do an initial spray with Iron X:
https://carpro.uk.com/products/iron-x-500ml
This gets the bulk of the brake dust off.
Then follow up with Bilberry Wheel Cleaner which also does the wheels:
http://valetpro.eu/bilberry-wheel-cleaner.html
Seems to do a great job.
For any remaining grease, I've used Elbow Grease De-Greaser:
https://www.tesco.com/groceries/product/details/default.aspx?id=294530429
This process should keep your bananas nice and clean while being kind to the finish. If you want to be super OCD about it, apply some sealant or wax to them afterwards.
Like SC, I use Iron X, but use Dooka wheels instead of Bilberry. My wheels and calipers are looking great after 7 months and 6500 miles.
Mine were treated with siramik when they were new.
I had mine treated with GTechniq C5 from new and use GTechniq fallout remover/wheel cleaner when I wash the car. I've got Bilberry wheel cleaner but don't find it that great.
My calipers are black though so not as difficult to keep clean.
One thing I would say having lovingly cleaned mine yesterday, is that I'm now seeing lots of very small stone chips on the wheels. I even have a couple on the calipers. I think Macca mentioned this a couple of months ago and I suspect the teledials may be susceptible to this.
There are PH neutral cleaners about, this is what I use after having bad experiences years ago with acid cleaners. Good wheel cleaners that I use are Angelwax Bilberry (buy the big bottle and dilute to the strength you need), Auto Finesse Imperial and for the not very dirty at all very soft approach Auto Finesse Wheel Soap Revolution. I also periodically use a Iron Remover to remove bad brake dust (again, there are good less abrasive ones out there) and Tar remover for black tar spots every so often. Do this and all you'll have to worry about is the stone chips.
