We have had 4 x 1.9's in our workshop this week that have eaten their swirl flapsEither of those. The lower suspension and Q2 diff are well worth having. But with any post-2006 16V jtdm (CF4 'plastic' manifold) you must beware of the swirl flaps and if not already removed, remove them immediately.
Autolusso - Swirl Flap Delete
Love my Q2 since sorting this (and blanking the EGR and getting it mapped out). The extra 20bhp of the Ducati would be nice, but personally I detest the trashy side-stripe decals that many are fitted with.
AFIAK the flaps will all be closed when the engine is idling which helps to create more air turbulence in the intake. As the engine rpm increases the flaps begin to open and once you get to 2,000 rpm (ish), they should be parallel to the airflow thus creating no resistance at all. The purpose of swirl flaps is to control the air flow into the inlet, to make it turbulent enough for optimal fuel-air mixing even when the engine rpm is low. It's claimed to aid low-end power and torque whilst helping to eradicate some of the NOx emissions. So they were indeed put there for a good reason. The problem as we all know is that some cars have lost a flap, or two, and the tendency is for them to follow the lead of gravity and get wedged between the valves and pistons. This can write off a perfectly good car as the cost of a replacement or rebuild can be too much for many owners. Many owners report no issues at all but it is a known issue among a number of manufacturers and as most 156 based Alfa's are now out of warranty, it's a bill for the customer. The removal of swirl flaps can be made cheaper by planning it in with the cambelt change so it becomes a no-brainer really. Saying that, your swirl flaps must have good strong spot welds. :thumbs:My GT cloverleaf JTDm has done 114000 miles with swirl flaps and I've had no problems. They were put there by Alfa for a reason. What's the impact or consequence for removing them?
Sent from my D5803 using Tapatalk
Yer and I have seen cam belts do 100k too, it is just a matter of time until they come off, you have been luckyMy GT cloverleaf JTDm has done 114000 miles with swirl flaps and I've had no problems. They were put there by Alfa for a reason. What's the impact or consequence for removing them?
Having had both of these modifications done by the chaps at Autolusso (thanks again) I can say they work a treat, plus it's peace of mind that you've removed what's arguably the only real mechanical weakness of the JTD (we'll talk about water pumps another time). :thumbs:Yer and I have seen cam belts do 100k too, it is just a matter of time until they come off, you have been lucky
If you do an EGR delete at the same time the benefits from the EGR delete outweigh the swirl flap removal
Ned
I've had an Autolusso remap with EGR and swirl-flap delete and I can't say that I noticed any change in low down power, I do drive it like a Twin Spark though :evil:. The idle is a bit different and it is a little (only a little) smokier but the cars emissions are within MOT requirements and its actually gained a few more mpg as a result. The main benefit is that you are no longer diverting all the burnt diesel and carbon deposits back into the inlet, one of the causes of swirl flap issues. As the inlet goes though a cleaning process to remove all the deposits it must mean that the fuel-air mixture burns cleaner and better. :thumbs: While I was up in Penrith Dan showed me a pre-processed inlet and the stuff that comes off the inside is awful, it's no small wonder that the swirl flaps decide to emigrate and house share with the valves. As mentioned when it comes to cambelt time it's worth thinking about what Ned said above, not if but when and removing them sooner that later can save a massive headache down the road. :thumbs:Any degradation in engine performance from these mods?
With you engine (170 Cloverleaf) we can do:Any degradation in engine performance from these mods?
Hi Ned,With you engine (170 Cloverleaf) we can do:
Swirl flap delete
EGR delete
Hybrid turbo
For £1,300 inc VAT, if you car is the 170 BHP this will give you around 260 BHP reliably, if your car is the 150 BHP you will get around 240 BHP, the difference is in the injectors and fuel pump
Ned
Hi AndyHi Ned,
How much would swirl flap delete, egr blank, remap, timing belt and service be?
Car is in at a local garage in Brighouse for the timing belt and service but after reading this I may cancel as the belt needs doing and I don't want to have to do the belt twice.
Andy
You don't actually need to disturb the cam belt to remove the inlet manifold. The HP fuel pump drive pulley has 2 bolt holes that allow it to be bolted to the crankcase, keeping the cam belt tensioned and immobile while you remove the pump so the manifold can come out.I don't want to have to do the belt twice.
Fair play. Thank you for the advice. I will get the belt done at the local indie and then take it to Ned or someone who knows a what they are doing with the removal and remap.You don't actually need to disturb the cam belt to remove the inlet manifold. The HP fuel pump drive pulley has 2 bolt holes that allow it to be bolted to the crankcase, keeping the cam belt tensioned and immobile while you remove the pump so the manifold can come out.
If the belt is due, this isn't worth bothering with, but delaying swirl flap removal because the cambelt is recent, is an imaginary excuse
However I did all that as the belt was mid-life, then found I had two flaps missing - one stuck in the inlet tract, the other having mashed the head and valves. So I ended up replacing the belts, idlers and tensioners anyway.
