i'm pretty sure if you unplug battery for 30 mins and plug back in again when you switch the car on again it will attempt to reset the flaps, as it sounds like that might be at least part of the issuehmm, its cold at the vent, on the passenger side, but warmer on my side. At the middle right hand vent its just normal air, slightly cool. Over 25 degeees outside its useless, i do an air exchange instead by opening all the windows..
put it this way, in the heatwave i didnt get out colder than i went in, ever. missus 147 is cold in minutes.
Either the control flaps are not working, assuming dual zone climate control, or the AC needs regarding. The pipes to the evaporator in the dash come in at the side, when the car is low on gas, that side gets coldish but the side away from the connection pipes won't as the gas evaporates as it passes the pressure reduction valve on the way into the evaporator.hmm, its cold at the vent, on the passenger side, but warmer on my side. At the middle right hand vent its just normal air, slightly cool. Over 25 degeees outside its useless, i do an air exchange instead by opening all the windows..
The battery doesn't need disconnecting for that long. I has some AC control issues with my 156 which meant the control unit needed connecting and disconnecting several times. As soon as the power to the controls is removed and restored it resets itself. Takes a few seconds.i'm pretty sure if you unplug battery for 30 mins and plug back in again when you switch the car on again it will attempt to reset the flaps, as it sounds like that might be at least part of the issue
[email protected]
Yep, I reckon gas is low.I know the battery code off by heart... yes my car has been that bad in 2012, id have to diconnect the battery every journey... and now my ecu is corrupt (checksum error)
Back tot opic, ill try a reset if not im guessing the gas is just low if its not very cold on my side but it is cold on my missus side![]()
