had battery off to charge put it back and code light stays on, what is the solution? Please no old wives tales!! Many Thanks
rub your onions in salt water before pickling i find it helps a lot :D nah poss key needs re programming by inseting master till light goes out then normal till light goes out then main again i think? what harm can it do what car is it and how old
Did you have to resort to inseting the master and doing a few switchings as we have reported on here quite a while back or did JB tell you a trade trick he has wink
Discussion Starter · #7 ·
I think the problem was the battery terminal connections. I think the terminals and the leads have to be really clean and tight to make a good connection. The immobiliser seems to be very voltage sensitive and whilst the connection may be good enough to spin the engine it may not be enough to disengage the electronic immobiliser
