1 - 9 of 9 Posts
Hi fellas, as it says on the tin.
I've had to get jump starts twice in the last few days as my battery seems to be dying out.
I have the car (156) a year since importing it and never had an issue, she's always a first time starter.
I think I need to replace the battery. Think I paid about 70 quid for a powerful battery in my last car so was wondering if any of you good folk could recommend anywhere I could pick one up a bit cheaper.
I'm based on the southside of Dublin close to Kimmage/Rathmines/Harolds Cross areas.
Appreciate any advice. :thumbs:
If you're buying a battery:
Go to this place: City Auto Components MOTOR FACTORS
Ask for Brendan and say Rory McDonald sent you....
Reminds me of a trick we used to play on a work night out when there was a tab and we would tell any latecomers that you have to say "the owl flies east in the Autumn" to the barman to get the fee booze!
The puzzled look on those barmen's faces!
I might use that line too ha!
Right Curly and Moe, who's playing Larry?
That's a genuine tip....
Thanks for the help folks.Feel a bit awkward dropping names of people I don't know but if they have affordable batteries I'm quite happy. :)
Any ideas on what I can expect to pay folks?
The 156 battery doesn't look the easiest to remove, is there anything tricky to it?
I changed the battery in my last car, a Saab but there appears to be some additional connections on top of the battery in the Alfa.
Please do keep us posted as I think I'll need to change the battery in mine at the end of the 'summer.'
Update time: :)
Went to City Auto Components as kindly posted above.
Can't think of the brand just now as I'm at work, I didn't name drop, feel a bit odd doing
that :D but the chap behind the counter was very helpful.
I picked up a new 72AH battery, which was stronger than the one which had died (66AH)
for 79 euro.
Replacing it:
I have a 156 JTD Multijet Diesel and the engine cover is a pain in the arse because it limits the access to the battery.
The tricky bit is opening the battery strap which is tightened with one single nut which you will need a 13mm socket to open but you will also need a long ratchet arm to get to it so you can open it and be careful because it's very easy to drop both the nut and/or the socket when you get it off.
After that it's very easy, a similiar size spanner will open the terminal connectors and after that Robert is your father's brother.
Slip in the new battery and connect up.
It took me about 20 mins because it's hard to get your hands into the small spaces the Alfa guys have supplied but it could probably be done quicker.
All done now anyway and she's starting like a dream. :thumbs:
Update time: :)
for 79 euro.
Replacing it:
Great stuff! :thumbs:
1 - 9 of 9 Posts
