Before today, I drove my 156 last Thursday and I'll be the first to admit the battery wasn't sparking her into life with a short, sharp shock.
So, today I came to start her and nothing. A momentary groan from the starter motor then red lights and that disconcerting click, click, click.
Using a spare battery I managed to start her OK and thought a 13 mile run to my destnation would charge the battery up.
Before setting off for home again, I measured the voltage across the terminals at 12.46V so I confidently turned the ignition and .............. red lights and that disconcerting click, click, click.
BTW, the selespeed pump motor ran perfectly OK.
Is it possible for a battery to appear fully charged (volts) but have no power (amps) to turn the engine?
I've just taken a look and the volts are still there but nothing else.
Now, how on earth do I remove the battery, specifically the terminal box sitting on top of it. It seems solidly attached to the battery!
The car is a 2001 156 selespeed 2.0l.
many thanks
undo the positive terminal and the box comes out with the cable...
btw my car usually has about 12.1-12.3V after a few days and starts perfectly fine..12.46V is almost a fully charged battery
Don't be fooled by voltage readings alone - mine was recently the same, but had a dead cell, now replaced
12.46V is not fully charged.
Anything below 12.6V needs charging.
12.2V is technically flat.
