Yes you could do. You could buy a couple of metres on a roll, cut it to length and crimp on your own ends. Its all readily available on ebay.I want to replace the battery earth lead and install a quick release connector. Can I use two separate leads instead of the Alfa one which connects to the body and then gearbox?
If so any ideas of the length required?
Any particular symptoms or just the usual low voltage histrionics?I've changed quite a few earths now, they are starting to become problematic.
Just the usual stuff really, same problems as what bad batteries cause. So cranking is usually a giveaway that there is either a battery or earth problem.Any particular symptoms or just the usual low voltage histrionics?
I would not do it. You risk creating an "Earth loop" and potentially risking electrolytic action.There could be other issues, vis a vis any loop acting like an aerial picking up noise and getting into sensitive devices - engine management - radio - etc. In fact you could produce a multitude of unintended loops. Alfa did not do it that way by chance.:rambo:I want to replace the battery earth lead and install a quick release connector. Can I use two separate leads instead of the Alfa one which connects to the body and then gearbox?
I’m a long way off knowing much about electronics/electrics, so apologies if this sounds as thick as pig crap. I wasn’t thinking about modifying the lead, just looking for a similar much cheaper alternative. I took the airbox and battery tray back out this morning, Xmas boredom��. Cleaned the chassis earth up and measured the lead to see if it’s the same as the 156 lead. I wonder if the earth cable, battery to gearbox, is one piece and the chassis clamp is just crimped on about 35cms from the battery. It doesn’t seem like there are two cables within the sheathing. So if 2 new cables are used, one from battery to chassis and then one from the same chassis clamp to the gearbox, how would that be different to the original?I would not do it. You risk creating an "Earth loop" and potentially risking electrolytic action.There could be other issues, vis a vis any loop acting like an aerial picking up noise and getting into sensitive devices - engine management - radio - etc. In fact you could produce a multitude of unintended loops. Alfa did not do it that way by chance.:rambo:
If you are saying, one earth lead going from the battery to the chassis, terminated with a lug to a bolt/nut and then a second lead fixed to the same chassis nut/bolt and on to the gear box, that's fine. Just make sure the two lugs on the chassis bolt/nut are nice a clean - use some electro-grease and connect the two faces of the lugs together with no washer in between - direct lug to lug contact. In effect this is just one cable, picking up the chassis on route to the gear box. Or the other way round picking up the gear box on the way to the chassis. That might be the better way as there is some suggestion it is block earthing problems which are causing coil packs to burn out.I’m a long way off knowing much about electronics/electrics, so apologies if this sounds as thick as pig crap. I wasn’t thinking about modifying the lead, just looking for a similar much cheaper alternative. I took the airbox and battery tray back out this morning, Xmas boredom?. Cleaned the chassis earth up and measured the lead to see if it’s the same as the 156 lead. I wonder if the earth cable, battery to gearbox, is one piece and the chassis clamp is just crimped on about 35cms from the battery. It doesn’t seem like there are two cables within the sheathing. So if 2 new cables are used, one from battery to chassis and then on same same chassis clamp, one the gearbox, how would that be different to the original?
That's exactly what I did, keeping the original routing just using two cables rather than the original single cable.If you are saying, one earth lead going from the battery to the chassis, terminated with a lug to a bolt/nut and then a second lead fixed to the same chassis nut/bolt and on to the gear box, that's fine. Just make sure the two lugs on the chassis bolt/nut are nice a clean - use some electro-grease and connect the two faces of the lugs together with no washer in between - direct lug to lug contact. In effect this is just one cable, picking up the chassis on route to the gear box. Or the other way round picking up the gear box on the way to the chassis. That might be the better way as there is some suggestion it is block earthing problems which are causing coil packs to burn out.
It was securely clamped without being soldered.Thanks Toxic,
I had a very brief glance at the chassis bonding point, but just thought it was a cable tidy, hence why I was asking if there are any other earth points worth looking at. Now with the battery, tray and air box back in and after reading yours and Pud’s posts properly, I can clearly see a big chassis bonding point?, could’ve easily had that off and cleaned it up earlier today.
When you cut the lug off, did you feel like cable clamped up okay with just the screws or did you solder it too?
It's the insulation rating, not the cable. Insulation is rated up to X degrees working temp. Other than starting, there is no heavy current in the cable - continuous current - and the cable is multi stranded, which has better current handling capacity and needless to say gets less hot than a single conductor or one with fewer strands. So the "internally generated heat will not exceed 70 degrees under normal conditions.All good then, cheers Chaps. Next question, cable temperature rating, a lot of the cable is rated up to 70*C, is that enough for inside the engine bay? It’s not like it’s in contact with the engine or any pipe work.
Can't go searching for coil pack burn out thread, so thought I would just attach it to this one about earth wiring.If you are saying, one earth lead going from the battery to the chassis, terminated with a lug to a bolt/nut and then a second lead fixed to the same chassis nut/bolt and on to the gear box, that's fine. Just make sure the two lugs on the chassis bolt/nut are nice a clean - use some electro-grease and connect the two faces of the lugs together with no washer in between - direct lug to lug contact. In effect this is just one cable, picking up the chassis on route to the gear box. Or the other way round picking up the gear box on the way to the chassis. That might be the better way as there is some suggestion it is block earthing problems which are causing coil packs to burn out.
