L
fit it onto the air-con pulley
then over the power steering pulley [ thats the long top section ]
then down under the alternator pulley
up over the tensioner
then under the crank pulley
then pull back towards the power steering pump & onto the the idler, you'll need a 15mm spanner to twist the tensioner to its max tension position.
think if the letter 'k' turned 90 degs clockwise
L
if no air con then there are only 4 pulleys & fit it in the shape of the 'star trek' symbol
