I have a spare 0260002453 (71719093). Worked well on my 3.0 2004, except the ASR button, if you have it.Hello All,
Does someone know where can I found a used ECU for my alfa 166 2002:
Gearbox ECU Details:
0260002783
zf6058001088
002f10095h1
fiat 467675070
Help will be appreciated...
Hi, this is the item I need for my 166 3.0, do yyou still have it and can sell to me?I have a spare 0260002453 (71719093). Worked well on my 3.0 2004, except the ASR button, if you have it.
Let me know, if interested.
Hello Fórum,I have a spare 0260002453 (71719093). Worked well on my 3.0 2004, except the ASR button, if you have it.
I have used both of them, as wrote before. They are not the same, as *453 has no STR button function. So if you have STR button, it will not light up and you can't use it. It all depends, either you have it or not.Hello Fórum,
I have a question Reading and trying to get my ecu since 5 months already, can someone tell me the Bosch ecu# 0260002783 and 0260002453 are the same?
Please advise,
Carlos
Yes it do has it, but all other fuctions should work properly?I have used both of them, as wrote before. They are not the same, as *453 has no STR button function. So if you have STR button, it will not light up and you can't use it. It all depends, either you have it or not.
ASR, not STR, mixed them up.Yes it do has it, but all other fuctions should work properly?
Thanks,
CArlos
