1 - 10 of 10 Posts
Looks like a bit of a mixture really, later type seats and wheels on an earlier alloy topped car with a Zender body kit on.
ON to the important bit, the gearbox, and I have no idea, certainly not an official Alfa box, so must be a local modification, the only yjing I can think of is if it came from a Fiat Bravo/Marea that uses the the same block as the Alfa, so it should bolt straight on in theory. They do not look like the Marea controls though.
HTH
there is a Marea auto with a 1.8 engine, but I have not found a 2.0, were the 2.0 engines the 5 cylinder ones?
so not sure it will fit, or was the 5 cylinder a 1.6 with an extra cylinder? In which case it may well fit.
A sele is not so bad, Mrs P has a sele in fact the sele system has been fine, its the rest of the car, in particular suspension parts, oil consumption, wiper motor and now a clicking CV joint,........Grrr
Ok
I found it its a special edition for Japanese market. In collaboration with Mazda they fitted the 626 gearbox in the 2.0 ts cf1 not quite sure if its 4 or maybe lucky 5 speed.
Might be a reliable gearbox.
Trying to find out what niggles I might encounter if I wish to import from SA's side.
One bad thing thou 1997 36000 km's no cam belt swap = more than 5 years:wow: think I might insist on a cam belt change before I import for sure.
Wish me luck:thumbs:
Why don't you do the cam belt
in Ireland
sorry SA, got confused with your avatar, thought of the Ireland flag :p , once the engine is open you might find other niggles to sort out same time. (Thinking of belt tensioners and related bearings).
Albeit, the pictures look great, like a well looked after vehicle and 36'000 k's is nothing in lifetime of this car, given the fact it has run in JPN, not much sign of abuse.
Asked goo.net for vin no and contacted alfa japan.
Bad luck though customs in SA is full of crap CAN'T REGISTER a car from JAPAN .
FKN Customs.
1 - 10 of 10 Posts
