Yes it is a Valeo clutch :thumbup:Not 100% sure but thought they supplied a Valoe unit as suggested in another thread which i believe is OEM alfa used part
AFAIK, it's only valeo that actually manufacture them. Even the ones that come in a different box from alfa...Has anyone used one, any good? Is a LOT cheaper than any locally available in OZ and need to order one quicklyaranoid:
Are the upgrade items also Valeo items with new linings and stiffer springs. sure the last upgraded item had what looked like a valeo cover plateAFAIK, it's only valeo that actually manufacture them. Even the ones that come in a different box from alfa...
Yes, I get mine done by CG clutchesAre the upgrade items also Valeo items with new linings and stiffer springs. sure the last upgraded item had what looked like a valeo cover plate
So there is a heavy duty clutch available too, where do I get that one?Are the upgrade items also Valeo items with new linings and stiffer springs. sure the last upgraded item had what looked like a valeo cover plate
From us but it will delay your order by a weekSo there is a heavy duty clutch available too, where do I get that one?
And QH - that's rebranded valeo too.Yes, I get mine done by CG clutches
If you buy and LUK or Alfa one one it will be a Valeo in the box
Ned
