Auto folding mirrors
1 reading
2K views 10 replies 4 participants last post by  marknewton1971
#1 ·
The AutoFold Mirror setting on my Veloce has somehow reset its self to ‘off’
Tried to set it on again and it just keeps going off within a few seconds, even tried disabling and re-enabling on MES but still the same
Both mirrors fold manually using the door switch so I’m stuck
Anyone?
#7 ·
according to MES, on older infotainment firmware, you can only force it via proxy alignment:
This function can enable/disable the menu for automatic folding of the side mirrors. The menu does not work/appear on models with old multimedia systems,
but auto-folding on these cars should be disabled when you set this option to "Present".
To enable or disable this functionality you need to execute this adjustment and select enable or disable.
PLEASE NOTE: You have to execute the PROXI Alignment procedure after changing this value! Otherwise your vehicle will not accept the changes.
#8 ·
Not sure I understand, you're talking about enabling it through MES, it was already enabled from factory but stopped working (set to ON but defaults to OFF), I disabled on MES then reactivated but still defaults to OFF
#9 ·
Do you have any idea what might have changed at the point it stopped working? I assume it had been working fine up until then? Was anything else changed or fitted or updated? Had you done anything with MES around the time you noticed they weren't folding in after locking?
#11 ·
No. I agree. I haven't adjusted the alarm on mine but I also enabled the auto high beam and my mirrors are fine. Could it be something to do with an infotainment update? I'm just guessing tbh. Yours is gen 1 but it was fine so I don't get it really.
