1 - 16 of 16 Posts
evening all, has anyone adapted the door mirrors to auto fold in off the remote , I'm after some guidance with the wiring if possible , thanks
I have seen a post about it on the Facebook groups for Giulietta ( cannot recall which one) of someone fitting it and selling the module too.
114140189695 is the ebay number
the seller also sells these
been looking for a better way to carry my eggs around with me for ages.
No nothing else to pay, took about 2 weeks which was fine, just struggling to decifer the wiring
Instructions included
Did you see this one the £45 kit, might help you?!
Installation Notes:
Thoroughly read this manual and wiring diagram before installation. Any damage caused by the wrong installation is not in the coverage of warranty.
The central door lock system is required before installing the smart side mirror auto folding system. The green (unlock) and blue (lock) wires must be connected with actuator unlock/lock (+) wires in accordance.
The power side mirror system is required to add on this smart side mirror auto folding system.
Main features
The system is compatible to the original car electric system and security system etc. The system can unfold the side mirror automatically when AC off and closing the door.
The side mirror switch must be ON to ensure the normal working of this system. If the side mirror is switched off, the system will be disabled.
Auto Folding and Unfolding
In ACC off, when the system detects the lock signals from the door lock actuator, the system will output 5s signal to the motor of the side mirror, the mirror will be automatically folded, when the system detects the unlock signals from the actuator, the mirror will automatically be unfolded.
If ACC on, the system shall be disabled automatically to ensure the driving safety. Only the original side mirror switch can fold or unfold the side mirror.
Smart Mode:
If the actuator unlocks wire (Green) is not connected, the system will enter smart mode. Turning ACC ON will unfold the side mirror automatically.
Overload Protection.
If the door is closed / opened too frequently, the system will stop to fold / unfold the side mirror to protect the motor of the side mirror.
Wiring Diagram
Yellow wire - ACC ON induction input (+)
Grey wire - Switch off of side mirror (+)
White wire - Switch ON of side mirror (+)
Black wire - Ground (-)
Red wire - 12V (+)
Green wire - Door open signal of actuator (+)
Blue wire - Door closes signal of actuator (+)
Orange wire - Output for close side mirror (+)
Brown wire - Output for open side mirror (+)
Further Instructions
Yellow, grey and white is not to be used.
The black wire (Ground) must connect with negative car wiring.
The red wire(12V) must always be on and be connected with the car wiring.
The green wire must connect with the green-orange cable from the car wires (unlock door signal).
The blue wire must connect with the white-black cable from the car wires (lock door signal).
The orange wire must connect with the yellow-green and yellow-red from the car wires (output for close side mirror).
The brown wire must connect with the yellow-grey and yellow-blue from the car wires (output for open side mirror).
How to access the car wires
For the output for close & open side mirror signal (yellow-grey, yellow-blue, yellow-red and yellow-green) if the colours apply to your car make, otherwise search for the signal. These cables are in the grey 2-way connector in the door card which have to be connected in the window/mirror console switch (ON THE DRIVERS SIDE).
To access the lock& unlock signal cables, you must remove the door card then the speaker from the DRIVERS door and locate it through the speaker on top of the door.
This package includes:
Wiring from module,1 roll of cloth tape adhesive looms wire harness, 6 red car electrical cable connectors, 6 blue car electrical cable connectors
Discussion Starter #15
I hadn't seen it so thank you so much , the top instructions were in the pack but not the actual wiring bits , cheers
Discussion Starter #16
Hi , got most of the wires but missing a white/black to go the blue wire , also it says the brown must go to the yellow/grey and yellow blue? Is it either or both wires need to be joined ,if you can help me out, thanks
1 - 16 of 16 Posts
