I've just done a belt change on a 1.8 and it seems there are two locations where the cam blocks can fit. Working from the left we've gone three caps in on inlet and exhaust cams. The one on the inlet is stamped B2 and the one on the exhaust B1. We've now encountered running issues which I thought were due to a faulty cam position sensor, but it it in fact possible to get the timing out with the blocks in the wrong location and cylinder 1 at TDC? We used a dial gauge and took all usual precautions.
See:
http://www.alfaowner.com/Forum/alfa-147-156-and-gt/206871-156-cam-sensor-help-please.html
That's the correct position for the blocks (if my understanding of the locations you've used is correct). To confirm this, have a look at the 3rd picture in the following post...
My cam locking blocks came from EB Spares and have the letters "I" and "E" clearly marked on then for
Inlet and
Exhaust. I'm not sure what B1 or B2 means on yours so it's quite possible you've got them on the wrong cams. Certainly worth asking the seller which block goes on which cam. Also, you definitely have the blocks for a 1.8/2.0 TS engine haven't you? The ones for the 1.4TS and 1.6TS engines are different so if you're using those then you'll never be able to get your engine timed up correctly.
Here's a quick check list for making sure you get the timing correct...
- Correct blocks fitted (for a 1.8TS in your case) in the correct locations (inlet/exhaust cam blocks fitted on their correct cams and over the cam lobes they are supposed to be fitted to).
- Cylinder number one set at exact TDC using a dial gauge.
- Both inlet and exhaust cam pulley wheels loosened.
- Cam belt fitted so that the white markings line up with the associated reference marks on the pulleys.
- Belt tensioned correctly (with the crank locked) and the cam pulley wheels then fully tightened before finally removing the cam locking blocks.
Don't forget that when setting TDC with the dial gauge there is a point where the piston will be right at the top for a couple of degrees turn on the crankshaft. You need to find the exact middle point of this which you can do by putting a mark on the crankshaft pulley / block that corresponds exactly with when the piston first reaches TDC and another mark when the piston starts to drop from TDC again. Then use the middle point between those two marks for
exact TDC. Also, when setting the belt tensioner, make sure the belt doesn't pull the crankshaft round at all (i.e. you need to make sure the crankshaft is locked solid so it can't move). If the crankshaft moves during tensioning then it will put the timing out.
HTH
