Hi Guys
Just fitting an ISO centre cage into my Brera centre console but cannot see any easy way to secure this. I have tried presenting the cage from the back but it isn't a good fit. Have also tried feeding the cage through from the front but again this isnt a good fit and it wobbles about.
Has anyone hot any advice?
Thanks!
Discussion Starter #2
Ignore me.. I was being an idiot :)
There was a black surround in the box which makes it a more snug fit. Still surprised there isnt any way to screw it in place but it should be fine
I didn't bother using the new radio supplied double-din cage. Found the original Alfa cage that screws into the trim is a much better option.
Removed the centre plate by drilling on the weld spots and filed the existing slots on the side of the cage a little larger to accommodate the new double-din unit slide and lock fixings.
Gives a good solid fixing with no movement.
Marc
