1 - 10 of 10 Posts
ASR light from the bord is on after a few meters of moving. Stays permanently !
Please help me with a solution. Where I have to start the search ?
Waiting advice
Get your fault codes read, post the error code and someone will help you.
I'd suggest a wheel speed sensor might be at fault, but worth getting codes read before attempting to replace anything
I will come back after I will have the error code.
I have scanned ECU engine with Fiatecuscan and it tells me nothing about this error with an ELM327 cable.
Maybe I have to scan ABS / ASR system. I need a VAGCOM cable, I suppose.
A
These errors are usually totally false. The problem is down to a low battery output. Changing the battery often fixes it and is far cheaper than taking it in for an hour or even half hours labour!
I have the error till september when the weather was warm.
I know that when is icy the led is light and blinking when the stability is poor, but now the led is staying all the time on.
I have read the error for ASR with an advanced soft - autocom
Error codes: 0052 - control module, intermitent, internal fault
0032 - wheel LR sensor, mechanical error, present
Also I have read some electrical errors: DF122, DF031, DF001
I am back again.
Where are the sensors for ASR ? Are the same sensors as ABS ? Do you have a draw for these sensor ?
ABS is ok, no fault, no light. I have to mentioned that I have change the front ABS sensor from an older version of Alfa Romeo - made in 1997. Mine is from 2002. Could be an uncompatible ?
The battery has over 13V voltage, so it is not the battery. I don't know where to check for fix these electrical errors: DF122, DF031, DF001
waiting advice
L
ASR & ABS sesnors are one in the same. if the connections are the same type they are compatible
if the tracking is out, or the steering wheel is not at the 6 o'clock position when travelling in a stright line, then the ASR will be disabled.
1 - 10 of 10 Posts
