Hi All,
The radio reception in my 155 has been rubbish ever since I got it, and I finally got around to trying to figure out whats wrong with it.
There's no power to the amplifier (I think it goes in the via the circular connector on the LHS of the amplifier box). I get no 12V between the brown/white and red/white cables.
Does anyone know where these cables start out? I can't even find any mention of the ariel amplifier (or any associated relays) in the handbook.
Everything else checks out OK (cables from amp to radio, rear window element).
Don't know if it's connected, but the remote release for the boot and boot light don't work either.
Anyone shed any light on this?
I think i might have a solution to your boot release problem ,i had it with mine. If you look in the rubber tube going from the boot to the body ,locate the two thick wires and see if they are broken. As for your aerial amp ,i have disconnected mine from the radio and put in a seperate aerial on the roof.
GOOD LUCK
