1 - 12 of 12 Posts
Hi All,
I found this on ebay, got to get mine done........ my mechanic (I've used him for years, and he is top drawer) is happy to buy my own parts.......
........ question, are these gonna be any good or should I just avoid it ????
Thoughts Please
Cheers to All
Peter
That is a contitech belt kit, Made by continental.
They are excellent. I fitted one like it to my 156 TS.
The tensioners are identical to the original Alfa ones. (revised later metal BTW)
The one shown is just for the cambelt anyway, the balance shaft one is listed as a seperate part.
These are the ones you need, buypartsby are cheaper than that too.
https://sslrelay.com/buypartsby.co.uk/timing-belt-kit-info.php?recordID=53
https://sslrelay.com/buypartsby.co.uk/timing-belt-kit-info.php?recordID=43
The first one is the cambelt + tensioners, the second link for the balance belt and its tensioner.
They used to show images of the tensioners to make things clearer, but for some reason they have stopped doing that.
Thanks Simon.......... I think These are for the 156 ...... But i get the drift........ My car is a 2003 GTV 2.0 ltr JTS ........ Maybe they are the same ????
Bu thanks for the pointer..... i'll speak to them on monday.
Cheers to All
Peter
Cheers to All
Peter
They are the same, I just checked. :thumbs:
Simon...........
I found the GTV kit on their site............ but they list two engine types for the JT ........ so I need to check the plate on the car.
Thanks again
Peter
You need both the CT970K1 and the CT877K2, as one is the balance shaft kit, the other the cambelt kit.
They were the only 2 I could see listed for the JTS :)
Thanks Simon............. Diamond !!!
Cheers to All
Peter
1 - 12 of 12 Posts
