Hi guys,
Was searching for about 1 hour and kept reading until the page number was on 10.
I recently acquired alfa leather (heated) seats. They come from an English Alfa and is supposed to bolt on a Alfa where driving seats is on the left. Therefor, I firstly changed the seats of the back but with a problem, the seats where you sit on, aren't straight en looks like they are kinda bend. Not a problem at all, a simple re-bending will do the trick. But if you look at the outerside of the seats, u can see a gap between the plastic body part and the seats. How can this be? Do i also need to change that plastic cover?
Than my front seats. What about the heated connector. On both sides i have running 2 cables. The yellow airbag connector and a white cable with 2 pins in it.
The english driving seat that wil go on the passenger place has 3 cables i can't understand. I would say a seatbelt sensor/airbag sensor and heating?
The english passenger seat has 2 cables just like the driving seat has, but i only need to rewire one cable from 3pin to 2pin. I can't find/understand if the heating cable is an extra cable or the power steals from anything else. Also, only attached the airbag connector for now and the light of seatbelt didn't went off.
Someone who can explain? There isn't anything usefull as info regarding the seats.
Vishal
Vishal
