A bit of help please....
Does anyone know for sure - with the 2 hoses that feed the heater inside the car, do they need to flow in a continuous circuit, of can you just blank off the ends at the block.
The heater is coming out of my car and I am trying to work out do I need to join the hoses - or can I just get rid of them all together??
Thanks.
That's what I was thinking, but to find something that joins two rubber hoses that run more or less parallel, has a 19mm bore and is a 180 degree hollow U bend - is not easy to find.
I thought of trying to do it with plumbing fittings - but I thought that was a bit [email protected]!
Thanks for the thought though.....
Anyone else.....
Usually heater circuits can be blanked off completely.
The heater feed & return both connect to the thermostat housing, so studying that will confirm.
