1 - 10 of 10 Posts
Just wondered if it was possible? Or is a lot of work involed i do a 60 mile round trip a day with 80% of that on duel carrige way so always feel its something useful mine is missing?
I've done it on other Alfa's but it appears impossible on the MiTo as the firmware in the body computer and ECU is not compatible.
Cheers for the reply all the first linl seams a bit steep for me :/ but i will put the second link into translator when i have 10 and see what it says, not very good at italian apart from the words plastered on the mito dash :/
They are downloading a new file from Giovanni Accini then doing a proxy alignment to get it to work. So it's not readily 'activated' from a menu after wiring in.
I had seen the wiring diagram before though and tested it, but hee haw happened, the body computer just wasn't doing anything about the inputs.
A DET told me he asked at a factory training week and was told it was 'impossible' with Examiner, but then that's oftern Italian (or Southern European in General) for 'I can't be arsed showing you'
Mm i should imagine there is a way as with most cases with factory build its cheaper to have the option than not. Ecu activation, loom plugs etc.
Well let me no if you find anymore
1 - 10 of 10 Posts
