Just discovered the plastic collar on my front o/s anti-roll bar bush has been broken into two halves by the garage that recently fitted a new lower wishbone, found the two bits wedged by wishbone. I've araldited them back in position for now. Anyone had any success with this method?, probably end up making a split alloy replacement. The reason i had the wheel off was to repair the 'pad wear' wire the garage had also managed to break :rant: (If you want anything doing properly do it yourself) :tut:
