Only had my gt jts a month probably done about 500 miles and I've already put a litre of oil in it. Being as im not sure when oil n filter was last changed if they used 10w40 instead of the 10w60 could that explain the high oil usage when I got the car I had to add 1/2 a litre to get it on the gauge :(. So basically is this normal or do I have to do an oil change and go from there ?
Its on the high side definitely...
I would change oil and filter and gauge it from there.
I had a jts GT before my 1.9 bkackline and went through a litte of 10/60 every thousand miles or so but that in 500 is a concern.
Did find the annoying flat dipstick difficult to read sometimes and if often took me a couple of goes to get a clear reading.
So it could just be a combination of lowish oil to begin with and ab ambiguous dipstick reading.
Good luck,hope it settles down.
Like Joey says, firstly change the oil and filter, use 10W60. Generally direct injection engines tend to dilute/contaminate the engine oil with petrol so you want to change the oil regularly, I do my JTS every 10,000km (6k miles) and it's been great.
This is a good point. I would do an oil & filter change and go from there. Oil that is old and broken down will burn faster.
