Ok so I got a cable for free from a friend of mine which used it for his Audi A4.
Sears helped me out with the correct KWP software so off I go to open my cable and bridge pins 1, 3 , 7 only to discover that only four of the pins are actually used on the cable :rant:
These are 15, 16 , 5, 7 from what I can see. Is this cable now useless to me ?
how many pins are in the socket? [ out of 16? ]
pin-layout said:
01. K-line ABS (ARS, ESP, TSR)
02.
03. K-line Airbag
04. Massa/Ground
05. Massa/Ground
06. B-CAN B-line
07. K-line Motor Management
08. K-line NetworkBodyComputer
09. K-line Stuurbekrachtiging/Power steering
10.
11.
12. K-line CruiseControl & Koplampen/Headlights
13. K-line BandenSpanning/Tyre pressure
14. B-CAN A-line
15. L-line NetworkBodyComputer
16. Voeding + 12Volt
5 is ground
7 is the engine comms K-Line
15 is L-line
16 is power
if there are spare pins solder 7 to 3 & then to 1, you should be sorted.
if you do not have pins use paperclips as pins, force them into the socket & solder them to 7
Hi there are 16 pins and total but only four connected. Hmm so I must just connect 1 and three to 7 (which is connected at present), will give it a go ! Ps what software do you use to convert the usb cable to a com port ?
