So, another tick on the list today. I have solved the rear screen leak. I took the car to a place called Premier Windscreens in Glasgow and they removed, resealed and refitted the rear screen. I had noticed that the C pillar dampness was due to water coming in at the bottom edge of the screen on the drivers side then the trim was acting like a giant sponge and drawing the moisture along it before gravity took it's grip and pulled the water down the side of where the rear seat back meets the C pillar trim. On closer inspection the seal had completely detached from the car body at that corner and I could move the windscreen in and out about 1cm, even managing to poke my finger into the car from the outside. I kept leaving a dry cloth jammed in there every day for a the last week or so and every morning after it had rained it was sodden with water. That'll explain the soggy interior trim, mould, moisture in the car and the damp smell in the boot then! Premier did a really good service. The chap removed the screen then took lots of pictures to show me what had happened. Basically the lip of the car bodywork that the screen bonds to had rusted and over time the water ingress had made this worse and detached the seal from the car. It was only surface rust but enough to dislodge the seal. The chap cleaned all the rust off around the perimeter, protected it then resealed and refitted the screen. He took lots of pictures to show me what he had done to so anyone in the Glasgow area I would highly recommend them. Price was really good also. It also turns out his uncle has a 166!
I'll keep an eye on the front screen but I have been driving about with both A pillar trims removed and I haven't seen any moisture in there so not sure if it was just condensation and the legacy of the car been sitting with moisture in it for so long and the continual leak from the rear. It's been absolutely peeing down here for the last few weeks (months) so would have expected to see water if there was an issue.
