I thought I would add my list of tasks needing done to the 166 Ti as others have done on here. I've split it into 3 different priorities and might never get round to doing some of them realistically! Some are more onerous than others. On the urgent list the water leaks look to be screen related so have a local chap coming out next week to take a look at those. I reckon it will require both screens to be removed, resealed and refitted to resolve it. The amount of water ingress into this car has been something else.
Urgent
Replace both rear tyres for MOT
Fix water leak inside – clear drain holes to engine bay and scuttle
Strip out Nokia hands-free kit - think it's causing a drain on the battery
Fix water leak to OSR C pillar - front screen leaking
Fix water leak to OSF A pillar - rear screen leaking
Fix crazy windscreen wipers
Source jack and toolkit
Source jack handle - turns out it was there all along!
Not so urgent
Fit new front discs
Fit new front pads
Fit timing belt & balance belt kit (due June 2021)
Fit new thermostat - old one seems to have given up the ghost
Fit new rocker cover gasket
Fit replacement NSR door lock
Fix wiring to NSR door loom in order to get lock working!
Air only coming through window vents - big concern this one, possibly urgent?
Air con not working
Get spare key posted back up from previous owner
Fit new pollen filter
Fit new air filter
Fit new arm rest lid
Replace damaged OSR door card
Replace gearknob
Replace cubby unit to dashboard
Source & fit drivers door B pillar rubber seal
Source small rubber inlays both rear doors – got one so far!
Source catch on drivers fusebox hatch
Clip to secure engine cover panel
Clip to secure scuttle cover panel
Driver’s headrest seems broken
Clean up/replace rear parcel shelf cubby hole
Replace damaged front passenger door card
Replace water damaged interior C pillar trim
Strip out interior and carpet - dry carpet out & refit
Nice to haves
Investigate why alarm doesn’t work
Source black retaining knob for CD cover in boot
Source missing bolts and fittings for boot carpet
Remount both side skirts
Respray back bumper
Front NS wing needs rust attended to
Fit new Ti wing badges and boot badge
Fit DSP door speakers
Fit DSP amp
Fit DSP loom - hard task on a facelift car
Fit DSP subs
Fit St/steel exhaust
Urgent
Not so urgent
Fit new front discs
Fit new front pads
Air con not working
Fit new air filter
Replace gearknob
Nice to haves
Respray back bumper
Fit DSP amp
Fit DSP subs
