Hi I have a 156 selespeed and it will not select any gears, the pump runs when I open the door but when you try to select it give a click but stays on N. The same in revers. The oil level looks ok.
Any experts willing to help would be very greatfull.
Any
Administrator
After reading the tech forum with all the info I have managed to get the selespeed working again,
1. checked pump running when opening drivers door
2. check contacts on battery and multi plugs
3. clean swarf out of inside box
4. slacken bleed screw and let the oil flow out
5. top up oil
6. put it all back together with fingers crossed
With great results.:)
