2006 faceliftYou might not get it on the chromebook as mes is a windows-based prog.
It won't be obdII either. What year is the 147? It's probably EOBD though.
kandlbarrett is right. it will mostly depend on the software some codes are specifically set by the manufacturer and thus for s universal tool will make no sense at all. I would get a proper ELM tool first of all the scan5 i got costed about 50£ and t can perform any operation in multiecuscan even calibrations and also connect to 90% of the fiat modules. For the other modules usually airbag and abs you might need the crossing cables or a k-line tool, it is a very cheap tool on ebay but driver installation for this on win 7 is a pain, I would expect the same in win 10.The cheap apps will ONLY talk to the engine ECU. If you want brakes, airbags and body then only MES will communicate with those ECUs.
Plus MES will not only give codes but correct description / interpretation for each code that comes up and so much more.
The cheap apps are good for engine but are all limited.
