Why do you ask?Hello,
Wondering about the 159 start button, is it meant to just be a press, or a long press (held down)?
I can understand his curiosity Mike, but why doesn't he state "why" then the answers could be directed as his issue, rather than people just having to guess the problem:irked:I had a phase 2 - as others have reported, if you depress the clutch then a tap on the button was enough, whereas if you push the brake pedal, the start button needs to be held continuously until it fires.
As to why, maybe he's just curious as to why it sometimes starts itself and sometimes doesn't, without realising the pedal chosen makes a difference?
Probably the same reason as me - the only manual I could find said quick press with one pedal down, but hold if the other pedal - my 2007 3.2Q4 needed the long hold with either pedal - so I thought something was broke.
Which I do everytime I work on something, lean in, shove the key in and press the button . . . nothing . . . it normally clicks after a while, normally after checking everything in sight, and I get in to press a pedal too . . .:thumbup:
Bri
Do you familiar with Phase 1 and Phase 2 car features ???...Probably the same reason as me - the only manual I could find said quick press with one pedal down, but hold if the other pedal - my 2007 3.2Q4 needed the long hold with either pedal - so I thought something was broke.
Bri
