The rear 12v socket in my 159 SW has stopped working. Its not the fuse, I must have damaged the wiring somehow when investigating polarity in previous jobs last year.
My question is about wiring: What route does the wiring take from the battery to the cabin in the 159? I would like to add an extra 12v socket for the rear seats of the car and I would like to be always on (not cut out with ignition off) as I have a solar panel for trickle charging the battery while I'm away from the car for long periods (airport car park).
Ideally, I would like to run a new cable from the battery terminals to the 12v socket. I plan to include an in-line fuse at 15a or 20a, so I can also run a tyre compressor from the same socket.
I don't want to mess up the firewall between the engine and the cabin and I don't want to run a cable that passes outside the vehicle (out near the windscreen, then in the passenger door hinge!), so is it possible to add a new cable to the existing cable loom - where in the engine bay does the wiring pass into the cabin? Could I connect from the fuse box perhaps - is there a spare always on connector in there?
