You have to have the ignition switched to the "on" position, that is the MAR position. It does not matter if the engine is started but it is also not needed.
has your bt obd adapter removed redundand/incorrect termination resistor from can lines?most of cheap ones have resistor(120R) soldered between pins 6 an 14,and such is not right termination.check with ohmmeter and or google for your device. do you have all drivers installed?
Just taken the Bluetooth adapter apart and between pin 6 to 13 don't appear to be attached to the board(see below pic)
Sorry for late reply, for some reason I didn't get any notification - need to check setup on AO website.
I'm not sure what you are presenting on the photo - is that photo of OBD connector? Have impression it is not.
