Version Release notes
3.0.0.0 Major Release
- AlfaDiag has been migrated to the .Net 2.0 framework.
- Added ME3.1 EODB ecu.
- Added MY99 airbag ecu.
- Added native implementation of XP styles.
- Added configuration option to disable XP styles.
- Added ability to change the graph colors.
- Enabled user specific configuration setings for application settings. This allows different users to have different application settings.
- Implemented cancel option for routines.
- Added code to correctly handle unsupported actuators on ecus that do not have or support a given actuator.
- Changed format of the connection test log file.
- Trail output of connection test to log file.
- Read serial ports at runtime.
- Implemented a specific FTDI driver.
- Modified ISO and KWP serial device code to simplify protocol timings.
- Add warning to Idle and Self Adaptation reset.
- Fixed some ME7.3.1 ecu sensor scalings.
- Internally cache ecu definition on connect.
- Disabled actuators button for ecus with no actuators.
- Fix multiple sensor not supported popup when ecu disconnects.
- Increase default timing values KWP and ISO devices.
- Fix ME7.3.1 lambda probe, Advance Angle, Throttle Angle, Fuel Trims conversion bug.
- Fixed signed conversion problem affecting some sensors.
- Fixed a Vista bluetooth serial port naming convention bug.
- Updated the licensing software version to resolve a Vista execution problem when laptop > 3GB memory.
Still no ABS?:(
There is more to come, development never stops !
