1 - 9 of 9 Posts
Can anyone tell me the best place to get a USB lead to connect to my 156 selespeed so I can use AlfaDiag.
Also will a VAG lead work?
You need a VAG-COM KKL 409.1 USB lead. I got mine from ebay (Hong Kong seller!)
Don't get an ELM 327 because AlfaDiag won't work with that.
and look at the Alfadiag FAQs when you do get to connection time - found I had to significantly extend the connection timeout settings to get mine to connect and stay connected to the ECU
None of the sellers appear to list this lead with compatability to Alfa's. Is this definately the right lead??
PM me , I have 2 working leads with the airbag modification, tested on my Selespeed...
p.s. it is OBDII so works on most all European cars (if you have the proper software !)
1 - 9 of 9 Posts
