Hi Guys!
Before purchasing AD, Iv'e downloaded the trial version. For many a resons AD trial just does not want to work. BTW I,ve purchased the KKL usb cable.
I was wondering if it was just the trial version or does the same apply to the full version?
So are there anyone out her using AD on Vista home basics? And does it work or are there problems being experienced.:cry:
You need to run AD in administrator mode - it should work then.
Right click on the AD icon and go to properties, it is a check box.
(Sorry fingers are cold so I can not type well today)
I run alfadiag on vista and yes you need to use it in administrator mode, you also need to go into configure on the alfradiag programme itself and click on interface and check that driver is on COM2 and therefore matching COM2 on your ports in the control panel. Good luck
Discussion Starter · #6 ·
Thanks guys for the responses!
Ive tried all that stuff but for some reason the only thing that happens is for a brief second the spinning wheel (time bar replacement on vista) appears and then nothing.
Does this mean that I'm going to have the same problems with the full version?
there are about 400 + AO members using Alfadiag, and I have not heard of these problems...
