hello guys,
my alfa romeo does not work at all, the manual switch do not even work.
i have read all the threads but mine does not move at all or sound like its moving?
does the roof have a separate ecu? if so where can i get one? is this likely to be the problem.
thanks
steven:cry:
Sounds like you have no power to the switch, silly question but have you checked the fuse first? If so and the fuse is ok, check the switch has power getting to it, then check the sunroof motor has power also. if no power getting to the motor its probably the switch. If the switch has power and the motor doesn't, then probably its the motor. Hope this makes sense because I've
read several times and it doesn't to me anymore lol, its a process of elimination as always with electrics. Check the earths are good also and not corroded. Have fun.
