1 - 9 of 9 Posts
hello. I have some problem with my ar 147 2006 radio. I connect original radio enter security code and it works perfect until i turn off and wait about 10min and cant on my redio. it dont respond to any button. but if I disconnect it and connect again radio start working again and don't ask security code. maybe someone have some ideas how to fix it?
sounds as if there is a problem with the connections, maybe someone changed it in the past.....
Make sure you have a continuous +12 Volts on connector ISO A7 (NOT a switched +12), and the CAN lines are connected on ISO A1 and ISO A3
+12 working fine and cans are in they place.
and idont understand why radio dont ask enter code then i disconnect it and connect again?
and i dont understand why radio dont ask enter code then i disconnect it and connect again?
on the 147 and gt the radio and bodycomputer have a relationship with each other. The code is only asked for once, when the radio is installed in a different car, or when the bodycomputer is exchanged.
So it is normal that the radio does not ask for a code after power disconnect.
1 - 9 of 9 Posts
