Hello,
I have a problem with my car. There was an oil leak in the cooling system, I thought was the head gasket blow, when i took the gasket off it look good, not blowed, but i replace it with a new one.Oil still is coming in the coolant! Does any one can help with this problem? Definitely is not the gasket. Where the oil may come from? Thank you,
Marinos
What engine does it have? I had a similar issue which was a split in the oil cooler. This was on a 2.0ts engine in a 147.
Good luck.
The engine is 1,8. Where is the oil cooler ? I cannot find it or see it, please advise if you know, thank you very much
It is an oil-coolant heat exchanger.
They fail internally and you end up with oil in the coolant.
The oil filter is mounted on it.
