Hi all,
I've recentley removed my standard Alfa gear knob on my 147 and replaced it with a standard leather one. The problem is the gear gaiter doesn't fit over the bottom of it properly and keeps dropping down to reveal the metal shaft. Not a huge problem but annoying all the same.
My question is, is there a different gaiter you can get for the 147 taht will fit it properly? Or can you buy a gearknob and gaiter set?
Thanks.
Had the same problem when I changed my geargaitor for one off ebay, it was too loose around the bottom of the knob, just bought a press stud kit from hobbycraft and moved the stud so it was tighter around the shaft, cost about 3 quid and came with the punch and tool to install the stud dead easy fix and looks much better. And loads of gaitors on ebay to choose from if you need to change that
