Hi,i own a 156 2.5 V6 24Valves,engine code 32401,and would like to know if engine code 32405 is compatible with my car,The present engine is damaged and i found the 32405 as a replacement.
Please advise.
Luwi.
32401 is the CF2 156 engine.
32405 is the later CF3 156 version.
I'm sure the core engine should swap fine, but you may need to swap some external bits over from your old engine.
Hmmm, the CF2 and CF3 engines use different ECUs. So it could actually be more effort than "swap some external bits".
Unless the idea is to simply use the block and head from the CF3 in the CF2 car, leaving all the rest of the CF2-related electronics and pipes in place.
