I assume that you have had a look at the wiring diagram.
http://www.alfaowner.com/Forum/alfa...y-156-sportwagon-pleeeeease.html#post15219465
To debug you need a voltmeter and measure voltages in the curcuit
Measure the voltage at the motor N85 (Pin A). If you measure 12V here the wiring from battery is ok. If you don't measure any voltage the wiring towards the battery is broken.
Measure the voltage at the motor N85 (Pin B). If you measure 12 V here the motor don't get any ground connection through the speed regulator M72. If you measure 0V the motor is broken. To test the circuit you can try to ground this pin with a wire. If the circuit is ok the fan should run a full speed when you ground (make sure it is Pin B you ground and not pin A else you will blow the 40A fuse)
Measure the voltage at the speed regulator (Pin A). If you measure 12 V here the motor don't get any ground connection through the speed regulator M72. If you measure 0V and measured 12 V at Pin B on the motor the wire is broken. If the speed regulator is working you should measure a variable voltage that will vary with the speed step you set on the dial. Lower (closer to 0V) at step 4.
Measure the voltage at the speed regulator pin B pin 1. If you measure anything here above approx. 0.5V the wire or ground connection is broken.
Thanks a lot for answering Henrik_45 :wink_org:
Yes, I've been reading a lot on this issue. I have downloaded the eLearning tool, revised the diagrams, the explanation of how it works and have researched a lot
about this issue. Yesterday I even found a post by a polish user who explains how to fix the speed variator, and maybe I will do that, but first I want to be shure
that my speed variator is damaged:
Naprwa opornicy (rezystora) nawiewu klimatyzacji Alfa Romeo 156 TS
Because of this I am fond of knowing more about the electronics of the car and being able to fix this problem myself. Even so I have some doubts about the checks you explain:
1) To do these checks, do I have to turn the fan dial on any particular speed?
2) When you say measure the voltage at some Pin, I have to put the positive voltmeter probe at that Pin and where do I have to put the negative voltmeter probe? To some other Pin, to the car chassis that is grounded or where?
3) To do these checks, all the parts (fan N85 and variator M72) have to be mounted or unmounted? And related to that, I take the measures on the connector of the cable
or where?
4) Among all the checks you explain, the one that can prove if the speed variator is working or not is that one "If the speed regulator is working you should measure a variable voltage that will vary with the speed step you set on the dial. Lower (closer to 0V) at step 4. ", am I right?
The explanation of eLearning about the M72 contains that:
The distribution actuator N80 is controlled by the control unit M70 from pin 16 of connector A, receiving a supply for controlling the potentiometer from pin 2 of connector A and sending a feedback signal to pin 9 of connector B.
The electronic governor M72 operates the fan at different speeds: it receives an input signal from the control unit (from pin 3 of connector B) and transforms it into a variable voltage signal that controls the fan. This voltage control is also stabilized, i.e. it is independent of the battery voltage variations. The governor supply is controlled by the ignition (INT/A) from fuse B10 up to 2/99 or fuse F6 of the additional fuse box B98B from 2/99, is connected to earth and also sends the temperature control signal to pin 4 of connector A of M70 .
As seen in the diagram, the speed variator (M72) has Pins A, B, and Pins 3, 2 and 1 (G, A, C are for cable color).
5) Pin A comes from N85, where does Pin B goes? To earth I suppose, right?
6) Pin 3 receives an input signal from the control unit. I think it is a variable voltage depending on the selected speed. But what are Pins 2 and 1 for? I can not find it anywhere.
7) And finally, is there any way to know if the speed variator is ok or not, having extracted it from the car, using a voltmeter and an electricity generator?
Excuse for the lack of electronic knowledge and thanks for the help! :vs_smile: It is really appreciated
