1 - 1 of 1 Posts
Dear All,
Using the FiatECUScan I check my ABS ECU and it come up with the following errors:
- Rear right speed sensor not feasible
- Front left load solenoid valve low value
As far I understand from different posts in this forum, the first error could be a damaged sensor, muck that prevents a perfect function or bad connection.
What about the second error? Could it be air on the pipes? I’m asking this because I had a problem on the clutch and it lost quite some brake fluid.
Can anyone give a help on this?
Regards,
Joaquim
1 - 1 of 1 Posts
