Greetings from another alfa owner,
I am having a strange issue with my alfa romeo 159 2.4 jtdm 2007.
Yesterday my check engine light turned on but the problem is that the light is flickering . It is not a solid light on .
I hooked up my Obd reader and uala no error code reported from the engine ECU.
Took it to a friend of mine wich has more specialized obd equipment but still no error codes .
This is a strange thing , i did a search on google also on the forum but information was scarce.
Do you guys have any opinion what the hell may be going on ?
I must state that the car is driving like always no loss of power , just this annoying light that flickers .
I really appreciate your opinions.
Enerik
Administrator
Alfa 159 1.9 JTDm Sportwagon
Maybe, you could remove and check if any of the connectors or wires are correctly fitted.
Just an update in this issue,
it looks like it is a fuel quality/ DPF regen issue .
Ii bought my diesel from a different fuel station on the day that the problem occurred and since then for 2 days straight the check engine light was flickering .
Yesterday I went to my normal fueling station that I buy all the time .
After a few km returning home the car went to a DPF regen and since then the problem has gone away .
If anyone is reading this your fuel might be bad or you need a dpf regen.
