U
unoimgr8st
·Guest
Hi there,
My Alfa Romeo 156 TS 2.0 2000 Selespeed requires the timing belt to be changed
So wanted to know what exactly does it requires, i was just assuming that it requires just the belt and it would do, but the shopkeeper said it requires a complete timing belt kit, which includes the timing belt, the tensioner adjuster, the idler bearing and the balance belt kit
So could some of you genius explain what exactly is the requirement and if can it be done at home?
Thanks in advance
Thanks in advance
